don't waste your time with building supply stores or plumbing stores ..... all the sinks they sell or can order are to big .... meaning they are more than 19'' in depth front to back . i changed out mine in my 4387 bayline about 2 years ago for a new one as the original sink did not shine any more . i got the new one in the carolinas on line at http://www.rvpartscountry.com/RvSinks they were good to deal with and had it in stock my advice if your taps are worn as well get them from them as well ....oh you might want to add that spray nozzel while your doing it . the install went good just had to cut out the rounded corners in the counter top out a bit and all was good ............hope this helps u.
I replaced the sink and faucets in mine a couple of years ago. went with a silgranite type thing I bought on ebay. Similar to the one pickture in the link. Had a little trimming of the existing hole but, for the most part, dropped right in perfect.
I got an exact fit replacement through Fisheries Supply last summer. Search their catalog. Was in the $300 range but worth it because of the exact fit. I also Wipe it down with wd 40 anytime we leave the boat for a couple of days. Stops all rust.
Allot of great feedback. Thanks! We've been looking at the big box stores as well as took the journey to IKEA. There are options but most include enlarging the hole which I'm hoping to avoid.
