4788 Isolation Transformer behind icemaker
    I’m starting the installation of two isolation transformers on my 4788.
    Several of the group have installed their’s behind the icemaker. That makes sense, lots of room, and an easy wire pull.
    When I investigated that area ist is large but I am very concerned.
    Looking at the floor of the cabinet, there is nothing beneath it. The floor is only held in by the little screws you see in the angle.
    Then reaching down I realized that the back 6” of the cabinet is unsupported. It’s hanging in over nothing.
    What bracing have you guys done to make this area stronger? How did you install yours? I am concerned that in rough weather I could have an issue.
    Thanks!
ID:	489572Click image for larger version
    Kevin,
    This is what we did. The 5/8” mahogany plywood is coated with thin epoxy and secured top and bottom. The transformers are thru bolted.
    MV Kia Orana
    Currently Alameda CA
      Originally posted by Woodsea View Post
      Kevin,
      I took out the icemaker, planning on doing just like in your photo. Then I saw how little material would be holding up that 150 pound weight. Started worrying.
      Thinking about the rough seas I get into occasionally and worrying about the corners of the cutout giving way.
      Perhaps I’m over worrying.
        Kevin - IMHO on a boat there is no such thing as over worrying about stuff that can go wrong - if not well thought out. Overthinking, yes. Over worrying, no. I’m going through my own angst fest on battery cable size for house battery interconnects.
        On the transformers - good location, just systematically think through sheer strength and reinforce as needed.
        Patti & Gordon Lewandowski
        Sammamish WA
        1998 4788 (April 2018)
        ”Knot Home”
        • Kwood
          Kwood commented
          I think you're right to be concerned. 150lbs shock loaded on that piece might be a problem. I'd look for a way to gusset it back to something substantial so the cantilever cannot flex under that load.
        Originally posted by Knothome4788 View Post
        Kevin - IMHO on a boat there is no such thing as over worrying about stuff that can go wrong - if not we’ll thought out. Overthinking, yes. Over worrying, no. I’m going through my own angst fest on battery cable size for house battery interconnects.
        Thanks!!!
        I really like the location that Woodsea and others have used successfully, btw...
        I would be a LOT more comfortable if that huge cutout was not there in the middle, but that cutout is necessary to access the throughhull fittings behind it, thats why it’s there.
        Part of me says to beef up thazt space, and another part of me says to use the area behind where the vaccume used to go. That is a pretty easy cable pull now that the icemaker is out.
        My thought would be to glue and screw a 3/4” plywood backer to the flat surface and then screw the transformers to that. Then I could get to the connections if need be to test, and the force would be down. All the screws would then do is hold the transformers from sliding around.
        Here are some photos of the area in question.
        Also as a FYI, the outlet is OEM for the vaccume. It is corroded because of the master bath faucet right above it, and it’s being replaced and relocated. Right now the breaker is tagged out of service.
        • Pacrimrat
          Pacrimrat commented
          Kevin,
          My thoughts on this location that It's very susceptible to water. Over the years I've had the tub facet leak onto the vacuum and the shower sump overflow flooding the area. I think behind the ice maker is the best spot.
          Chris JM2C
        Kevin,
        We installed our transformers this past spring. We had a couple of rough days off shore this past fall coming up the coast around Cape Mendocino. Worst being 10-14’ on short periods from three directions. Felt like we were in a Maytag for several hours. Happened to pull out ice maker when we got north on another matter and inspected. So far so good.
        Our transformers emit a slight hum. I can hear it in the salon and guest head when the boats quiet. I’m glad it’s not closer to the master stateroom.
        MV Kia Orana
          Kevin,
          That is a Great report!!!
          Sometimes I’m a worry wart!
            At the risk of sounding stupid, what is the purpose of installing isolation transformers?
            Rob
            Bayliner 5788
            'Merlin V'
            Vancouver BC
              I know one reason is to eliminate possible issues with the new electrical distribution systems at marinas - the ones designed to just about totally eliminate stray current in the water. Why an isolation transformer makes the new ELCI (?) posts a non-issue is beyond me. Other than that I'm like you on this topic Rob - more or less clueless.
              Sammamish WA
              ”Knot Home”
                The main reason is to eliminate low voltage DC currents from traveling through the ground wire of the shore power cable and corroding metals in contact with water. Here's a good article: https://shop.pkys.com/Isolation-Tran...able_b_37.html
                2013 Boston Whaler 130 SS
                  Technical details aside, here is a very high-level summary to explain things. Electricity requires a closed loop to be formed.Two boats sitting in the same body of water side by side form a loop between them by way of boat-1, through the water, boat-2, the ground (green wire) of the shore cable to the dock panel, ground-wire from the shore panel through the shore cable to boat-1. Low amps, as it may be, this current causes corrosion in metal parts in the water. Isolation transformer cuts the loop off since the 1-to-1 transformer in the isolation transformer inserts a magnetic path (non-current conducting) that prevents corrosion. Galvanic isolator is another way to cut the loop off. Galvanic isolator creates a high-enough resistance that blocks low levels of current (so corrosion is isolated) but permits high levels of current to pass (so short-circuit protection is maintained). Since the loop passes through the ground wire of the shore cable, your boat is safe from this type of corrosion (there are also other types of corrosion) if you are not plugged into the shore panel with a 3-pronged (grounded) connector/cable.
                  Enjoy!
                  bdervisoglu8@gmail.com
                  bulent@pacbell.net
                    The new wiring standards of dock pedestals has caused some issues with connectivity to older boats. We wanted to eliminate the hassle and this is a sure way to do so.
                    MV Kia Orana
                      Which leads me to wonder - why don’t 4788s have the grounding thingy rubbing against the propeller shaft like so many other boats? At least ours doesn’t. And our 3988 did. I wonder because our three shaft zincs were really corroded after only 9 months in our marina. Sorry if I’m hijacking the thread.
                      Sammamish WA
                      ”Knot Home”
                        That is one of the reasons I am adding them.
                        As I start to activly cruise I want to isolate my boats electrical system from the shore power system (and other boats) while still getting the benefits that shore power brings.
                          Posted on this once before. I placed mine in the aft cockpit lazarrette next to the battery charger. I wanted to create a new place to plug in too, since my boat is stern-in most of the time and the electrical pedestal is closest here. also, my boat lists slightly to the port and I wanted to counteract the weight distribution. Short runs for wire are also important. I then ran the wiring to ty in with AC up the starboard side directly to AC panel and added a breaker for this outlet. Then just tied into the appropriate electrical switch. The Charles G2 is only 30A but with the diesel furnace I do not usually draw more. If I do, I simply trip the breaker. Note: Charles calls out for a specific type of breaker, can't remember if it's thermal or magnetic. This setup also allows me to use the inlet on the side of the boat, and I simply flip the breaker to the rear inlet off. The area if the boat where G2 is mounted is simply retained by a 'shallow box' that keeps it put. The same area had originally held a start battery, which I had moved. And I still have access to crawl around the starboard side of the starboard engine. Not sure though how things are on the 47. Try placement first to see how it affects your boat floating in the water.
                          Ken
