OK, so I need to replace my start battery but can't get the exact replacement here in Nassau. So I need a new plan!!
The engine specs require a battery with 950 CCA with 160 minutes RC as a minimum.
The best I can get here is 800 CCA with a RC of 120 min
Not good enough!
So, my thought is to buy 2 identical batteries and parallel them.
My question is this: if I use the above mentioned battery specs (800CCA and 120A RC) and have 2 batteries in parallel does this mean I get 1600 CCA and 210 min RC?
Not good enough!
