Oil pressure sensor X referance sheet for hino
    Marine parts supply part number is 817164 for the oil pressure sensor. Dose not specify if it is Hino. last time I ordered a cam sensor it came in a sierra package, kind a pissed me off for the outrages price and shipping I payed. Thinking I was receiving a stock Hino part. So my question is dose any one know if there is a X reference sheet part numbers for a oil pressure sensor for a W06CTA 250HP HINO DIESEL. Any help would be appreciated. Thanks
    1993 43.88 bayliner motoryatch
    I had to replace one of mine on my HINO 250 since it didn't alarm when I turned on the ignition key. This part below is the one you need. If yours was like mine it was hard to rotate off. I found out afterwards there is a special socket to remove these items; but I ended up using a vise grip and gently rotated until I could unwind it by hand.
    https://www.ebay.com/itm/Genuine-Mer...!-1:rk:29f:0
    Genuine MerCruiser Oil Pressure Sender Sensor Switch - 87-805605A1 (Quicksilver marine parts).
    MY 3988
    M/V MMPOWRD
    Poulsbo, WA
      Look at the Hino database at the beginning of the motoryacht section . There are some part numbers referenced there .
      2013 Boston Whaler 130 SS
