4788 Cockpit Door Barrel Latch
    Hi All!
    Happy New Year. Our cockpit door latch fell apart this fall. I searched the site and found reference to the name barrel latch, but nothing about the specific latch. Have any of you sourced the identical replacement part somewhere? Any leads would be much appreciated. I'd love to find the exact same latch. Images attached.
    Jeff
    Barrel Latch? 4788 Cockpit Door Interior & Latch
    Hi Jeff. Haven't chatted in a while. Not sure whether this one is the exact hole profile, but google marine barrel latch and see what you can find. This one came up under our local eBay, shipped out of China
    https://www.ebay.com.au/itm/Boat-Bar....c100005.m1851
    Have fun. Cheers
    John H
    Brisbane QLD Aust
    "Harbor-nating"
    2000 - 4788/Cummins 370's
      Bayliner used mostly Perko hardware. I would go through the Perko catalog. You will probably find a good p/n from that.
        If it's not in the catalog call Perko directly. They make a few OEM products that are not in the catalog. For example, the anchor rode hatch hinges on my boat are not in the catalog . The ones listed there were the same size but the hole pattern was different . l called Perko and the rep gave me the p/n for the OEM hinges they supplied to Bayliner.
        2013 Boston Whaler 130 SS
          Thanks for the tips. I called Perko. Not very helpful, but she did suggest that I pull the old one off and look for a part number on the backside. Next step... Thanks for getting me on the right track.
