EH - 700. Hino Raw Water Pump Relocation
    I wanted to bring this subject back up to see if any progress has been made and if I can help,I'am not in the area now but will be later.
    Brad & Sharon
    Lady Jake
    LaConner,Wa. (summer)
    kailua Kona,Hi (Winter)
    Still on my to do list. I made a pattern, I just need to get some 2" aluminum or steel. My sticking point is locating the adjustment bolt threads. All I really need to for that is make a repeating punch, but there are other projects like a new diesel furnace, replacing the damper plates and replacing the water tank that have my attention right now.
      I get the priority of projects,been their more than once....Are their the same bolt holes on the right side as on the left side?
      Brad & Sharon
      Lady Jake
        The mount is, to the best of my knowledge, the same on all of the EH700 series USMarine conversions.
        The priority list isn't helped by my having been in surgical dry dock since September. I had cervical spine surgery and it left me very weak. Of course cutting all of the muscles in the back of my neck could have something to do with it. I get one good day of work then rest for two days. I'm expecting it will be a year until my stamina is fully restored, but that's life.
        • mswtjwonthebay@gmail.com
          PCPete, I understand your dilemma my friend. I had a spinal cord injury 2 years ago this April and I am still recovering. My strength is nowhere near what it used to be and my stamina has not completely come back yet.They tell me at the two-year Mark I will be as good as I'm going to get. Best of luck when your continued recovery.
        While it’d be nice to relocate the pump of the port engine to the starboard side of said engine, I only replace the impeller every two years so it’s not terribly high on the hit list for me.
        Pete, hope you get your strength back soon!
        Jim Gandee
        1989 3888
        Hino 175's
        Fire Escape
        Fyrflyer@ca.rr.com
          I’ve gotten pretty good at accessing the pumps as they are, and like Jim don’t replace impellers that often and prefer to remove the entire pump when I do for inspection. Even belt adjustments aren’t too bad to do on the port engine. That said, I did notice a water pump that might replace the kashiyama it came with. Looks like it could be a fairly simple replacement if it’s specs are enough for the eh700.
          https://www.sbmar.com/product/smx-12...al-water-pump/
          James
          Hurth 630's Onan 8kw MDKD
          Lowrance Electronics!
          MMSI
          316030379
          VHF
          CFA 2587
          Boating on Georgian Bay
          Currently on the Great Loop
            Thanks Jim, it's going to be a long haul. 70 isn't the new 21. I'm just getting so I can drive in light traffic but with someone with me. It's like I'm back with a learners permit.
            James, my only concern with that pump, assuming it meets the flow requirements, is that it's designed as a wash down pump. At least that's the nomenclature for the part. That leads me to think that it's designed for shorter duty cycles that we probably use our engines. The manufacturer would be able address that question and I really doubt that our current pumps are putting out 10 gallons per minute however, there isn't a description as to how many rpm the pump is achieving to get to that 10gpm. Our current pumps are probably close to 1:1 with the engine rpm when I think about the pulley sizes. It's a great starting place, thanks.
              My on idea on how to relocate the pump properly depended on me finding a slightly longer belt and then I gave up after looking...I keep meaning to contact suppliers but it's low on the list.
                Hi Pete,
                Under the description tab it does give flow specs at RPM's, not sure what's required as well.
                600 pump rpm, 10 gpm, 10 psi
                1200 pump rpm, 15 gpm, 10 psi
                2400 pump rpm, 30 gpm, 10 psi
                It's listing calls it a seawater pump in the header, then wash down pump in the description. Not sure which is accurate
                You're right though, I doubt it would be as robust and long lasting as our 30 year old Kashiyama pumps.
                James
                MMSI
                316030379
                VHF
                CFA 2587
                  James, the output could be adjusted by reducing the pulley diameter, so that's a solvable issue. The current pump has a threaded hole for the tensioner, so that, along with what will turn out to be an adapter for mounting would be required. I'd want to see how the impeller is serviced. The end plate elevation was missing, although I didn't dig further. I'm with you on the durability of the original pump. My engines have 3800 or so hours on them and they check out fine.
                  Earl probably knows how much volume and pressure are in the specs. I wouldn't be surprised if he's lurking at this thread.
                    3800 hours, wow, and I was impressed mine just rolled over 2000 hours while on the loop.
                    MMSI
                    316030379
                    VHF
                    CFA 2587
                      If I recall correctly, the threaded portion of the pump for the adjustment bolt goes all the way thru. With slight modification to the adjusting bolt, you can keep the existing pump and adjustment bolt. Only thread it thru the other side. I'm on and off working on a relocation bracket as well.. Just had allot going on lately. I'm really hoping that the next time I take off the pump for impeller change, it will be to also relocate the pump.
                        Thanks for all the responses,so I guess that the 4 bolt hole pattern on the pump bracket are only on the left side of the motor.Must be otherwise this subject would not come up.
                        Again thanks for posting and hopefully some one can figure out an easy solution...ya right.
                        Brad & Sharon
                        Lady Jake
