4788 490 Leak Fix Thread
This is a sticky topic.
    This would be a good time for us to document the leaks we have found on our 4788’s and 490’s
    If you could indicate what the symptom was, and what the eventual fix was, that would help future owners
    I’ll start
    ___________________________________
    SYMPTOM
    Water visible on the valence in the aft part of the salon and water driping from aft salon light fixtures
    FIX
    This was all traced to the radar arch interface with the flying bridge roof.
    After attempting to seal up the Radar Arch I solved the leak by pouring 1/2 gallon of boat resin into each of the sides of the radar arch at the inspection ports, and then re-driling new weep holes in the radar arch above the resin line.
    ____________________________________
    SYMPTOM
    Wet carpet in the master stateroom on both sides. This included wet carpet at the edge of the foreward head.
    FIX
    This was fixed by re-bedding the rail bases. Upon removal of the valance(s) the leaking was apparant as the rail base bolts were rusty and there was evidence of long term water seepage. I used new bolts 1/4” X 4” and nylock nuts with washers as the original bolts appear to be either metric or a odd ball thread pitch. The rail base in the foreward head was the easiest right above the porthole. Upon re-assembly I declined to re-install the port hole cover which resulted in a large shelf just below the porthole being usable
    _____________________________________
    SYMPTOM
    Wet bunk stateroom and mid stateroom mattrresses
    FIX
    This was traced to the rail base above the upper bunk stateroom berth. Removing the large panels above the berth exposed the rail bases where seepage was evident. Water had also been running aft into the mid stateroom.
    www.transferswitch4less.com
    where are we right now?
    We are a few days into our journey north and have had a bit of rough water. With the bow cutting through the waves, the bow wave is impacting the port lights and rub rail pretty hard. Water is leaking where the ceiling joins the wall above the port lights. I am wondering if water hitting the port lights hard enough could squirt the water somehow behind the frame. It does not seek to be leaking through the rubber seal. Could this be the port lights or am I facing a leaking rub rail?
    MV Kia Orana
    Currently Enjoying the PNW
      Well here’s my quick solution to try and isolate. Also found caulk missing under the rub rail under the bow sprit. So dug out a two foot strip and replaced with 4000 quick dry.
      MV Kia Orana
        Well... That sure is a interesting look. Just a bit Arkansas I think...
        I’m interested in what you find. I have an issue where in rough seas I get water ingress seeping onto the carpet starboard side, almost like it’s coming out from under the head compartment. Doesn’t happen in torrential rain, just when we run in rough seas.
        I’m suspecting a lower side rub rail leak.
          I’ve found there can be a tremendous amount of water pressure pushing against those portholes. Unless they are tightened down really hard, water can seep in.
          "Impasse". 2001 3988
          Cummins 330's
          Puget Sound
          "You don't want to be the richest guy in the nursing home..."
            Kevin, we have experienced a similar leak in our 490 in rough weather. In rough seas we get a wet spot just outside the master head door (not right next to the door, but a few inches out and an inch or two away from the step for the berth). We haven't done much in the way of troubleshooting this yet, as it doesn't seem particularly serious and we have only experienced it twice.
            However, it is something I want to address.
            GMS
            2008 Meridian 490
            2010 ArrowCat Express 30 (sold)
              Yep, pretty much the same leak.
                I've got a rough-seas leak in my forward porthole on the starboard side. I'm fairly positive it is water coming in around the gasket of the window in the porthole. I've tried cleaning the gasket and using liberal amounts fo Superlube without much success. I know some here have had success in replacing the gasket material but I haven't yet tried this. For now, leaving towel on the shelf below the window does the job to keep the interior and the mattress dry.
                Evan
                2001 Bayliner 4788 "Fifty / Fifty II"
                League City, TX
                  FWIW, each of the storage hatches next to the bow seat have drains. These drain on the “bin”is connected to the drain hole on the outside of the deck side by a small tube. If this tube comes loose water in the storage hatch drains into or behind the lockers and results in a wet spot on the carpet (in front of the master head if on the starboard side). The guys detailing our boat figured it out when I noted water coming in to the fwd stateroom. Probably not the cause here unless the rough water splashing up on deck is coming into the storage hatch because the hatch isn’t battened down. Removing the hatch and bin and reconnecting and or replacing the hose is on my winter project list.
                  Patti & Gordon Lewandowski
                  Sammamish WA
                  1998 4788 (April 2018)
                  ”Knot Home”
                  MMSI 368040470
                  • Knothome4788
                    Knothome4788 commented
                    Scratch removing the hatch. Probably bedded with 5200. Won’t budge. So next up is figuring out how to disassemble the starboard hanging locker. Sigh.
                  Here’s what we have discovered so far:
                  The chisel point of the latches actually contacts the plexiglass first and pushes the glass out of the frame. This was part of the leak. We trimmed off the end of the chisel and rebed did the plexiglass with marine silicone. It’s not leaking here now.
                  The gasket seal does not appear to leak.
                  The water appears to leak behind the frame where it seals to the hull. I retaped this with aluminum tape for the next leg. I suspect it will only last an hour but that should be long enough to determine if that is the culprit.
                  i experienced the deck locker leaking into the closet. The bottom of the locker is just some gel coated plywood. I fiberglassed this up and redrilled the drain. No problem since
                  MV Kia Orana
                    Guys- I’m probably crazy but where everyone finds water is exactly where the shower sump leak collects. It only happens in heavy seas, not heavy rains. Is there any chance water in rough seas could be flowing back thru the shower sump drain hose from the thru-hull and overwhelming the sump?
                    Drew Haas
                    1998 4788 "Painkiller"
                      I had a similar leak a few seasons back. I noticed significant wet carpet in front of our port side master suite closet after a rather rough water crossing.
                      After getting back to the dock
                      I closed up everything and sprayed all over the bow with a hose while the wife watched from inside. It was coming in around the outer edge of the port light frame, leaking down the inside wall of the closet and soaking the carpet all the way into the bunk stateroom carpet.
                      In my case it was the portlight frame caulking had dried out. I had to pull the portlights and rebed with fresh caulk. A bit of work but solved the issue for us.
                      4788 PH 2001, Cummins 370's
                      MMSI: 338013392
                      Call sign: Sea Daze
                      Exploring the Salish Sea
                        Hi All
                        If you have the metal Rub Rail I would highly recommend a bead of caulk on upper and lower sides,because you can't believe how much of a gap their is between the Deck and Haul joint their is if you haven't repaired/ replaced the Rub/Rail the gap can be from 0 to 1/4 in.and Bow and transom corners even greater.I used 3 tubes of 3M5200 to seal it when I installed our new Rub/Rail.
                        Also as said earlier caulking the port lights is a good idea......Good luck....Brad
                        Brad & Sharon
                        Lady Jake
                        LaConner,Wa. (summer)
                        kailua Kona,Hi (Winter)
                          [QUOTE=Knot_Happy;n452016 I had to pull the portlights and rebed with fresh caulk. A bit of work but solved the issue for us.[/QUOTE]
                          Can you let me know how the porthole is attached? Mine has carriage bolts that don't go through so they must attach to the outer frame. One is loose and just pulls out- doesn't look stripped so I'm reluctant to unscrew the others in case there are loose nuts on the inside. I've traced my leak to the port porthole and it looks like the caulking needs replacing.
                          1988- 3288, 1994- 3288, now Soul Asset: 2001- 3788 w/330s
                            Thanks for everyone’s responses! Here’s some more info:
                            Drew Hass, I don’t think the shower sump is the problem in my case. I’ve modified that area so that if/when the sump overflows, it drains into the bilge.
                            Knot Happy, I think this is where at least a portion of our leaking is coming from. I used aluminum tape to seal the frame to hull joint and now, with milder sea conditions only one porthole is leaking. How did you go about removing port lights?
                            Brad4550, I am thinking there may be some rub rail leaking as well. I have caulked upper and lower rub rails and it appears to be intact. Any chance it could be coming in from the screws that hold the rubrail to the boat?
                            MV Kia Orana
