I have a 1998 4788 with 330 Cummins engines. The Port engine pre heat alarm buzzer does not buzz when I first turn the ignition key on. The green indicator light comes on during the pre heat sequence and goes off after about 15 seconds. The Starboard engine buzzer and indicators function correctly. I have studied the engines manuals and wiring diagrams and have been unable to figure out what actually activates the buzzer which I believe is also the low oil alarm. I was told that the sensor beside the oil pressure sensor was a low oil sensor, but after looking it up and speaking to our Cummins Dealer it appears that this is a temperature sensor. Has any one ran into this or can point me in the right direction to solve my problem?
Carlo
Carlo
