I do not understand the +/- of these two types of transducers. Is a thru-hull type going to be more consistent and reliable than an in-hull version given the hull construction of the 32's?
This would be for something like a Garmin 441s (though I'm open to suggestions on a different model/brand at the lower price range as well) or the like and used in salt water. Does it merit drilling the hole in the hull? I'm not that much of a fisherman, so accurate depth readings would be the emphasis if that plays. Your comments appreciated, Dean
