It seems the folks that designed the 4788 Never actually had to fuel one up.What do you do to fill the tank furthest from the dock?Ive tried it by pulling the hose through Both windows, and from both the pilot house and the cockpit. Now I'm thinking of using the built in transfer pump.Any other ideas???
Fueling a 4788-gctid404507
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
Where am I right now? https://maps.findmespot.com/s/2R02Tags: None
What specific problem are you having? I put the starboard side to the fuel dock, fill that side, and then run the hose through the windows to the port side. This was technique was originally recommended here by mmichelich.
Access through the galley window to the port side is a bit easier than reaching over the wet bar to the starboard side. I'm able to lean out the window, attach the overflow-catch bottle to the vent, and open the filler with little problem.
Open up the two front salon windows (each side) and pass the hose and nozzle through the boat. cover the nozzle with a towel to keep boat clean. Wife has to remove canisters to do it. I will not stand on my head to fill the boat. Sometimes when not in a hurry will turn the boat around, but that is rare.
Started boating 1965
Thanks guys
I do the hose through the gally thing.
It works, but it would be great if there was a better way.
Dragging a fuel hose through the interior of a boat sounds like a disaster, especially since the hose is heavy and there's 15' between windows.
Have you considered adding a fill for the opposite side tank, so you can fill both from one side? I added an additional shore power outlet to the opposite side and it has worked well.
I use the through the salon method. It's much easier then the PH or turning the boat.
I've never spilled.
I've thought about putting in a transfer pump.
I normally fill at about half tanks. If you pumped one side to the other and only had one tank to fill it would be a lot easier.
This would be a good thing if you picked up a load of bad fuel. It would isolate it in one tank.
You would probably have to put in a float valve so you didn't overflow the receiving tank.
I've never spilled.
I'm going to give it a try and see how long it takes to move fuel over.
The salon/galley hose method is OK, but if the transfer pump is quick then it might be the ticket. It would just require two people, one to watch the fuel vent catch bottle.
I'm with Ishiboo, dragging a diesel fuel hose through the pilothouse or the salon is a disaster waiting to happen.
Fortunately, in Whittier, Shoreside Petroleum has long enough fueling hoses that I can reach the far fuel inlet by taking the hose in front of or behind the pilothouse of the 45.
See if your fuel dealer plans on replacing their fueling hoses in the future and if they might be putting in longer hoses.
Darby
A little off topic, but if you want to transfer fuel from one tank to the other, and you don't have a transfer pump, but do have the normal manifold allowing fuel pick-up and return from either tank, simply draw fuel from both engines (when operating) out of one tank and put the fuel return from both engines to the other tank. Fuel will transfer to the other "return" tank amazingly fast. if you do this, keep a close eye on the fuel tanks.
"Allante I" Rayburn 75
Previous: '97 4788
Darby
