Galley Sink Drain Odor
    When we were out this past weekend we noticed that there's a foul odor coming up the sink drains in the galley. Anyone have a good suggestion for how to remedy this without replacing all the drain lines? I suspect it has to do with sea water back-washing into the drain thru-hull and the little bit that gets in there sitting and creating the smell. Any advice would be great!
    James
    2000 4788 | "Freedom"
    Gig Harbor, WA
    11' Novurania w/40hp Yamaha
    Cummins 330's and Westerbeke 8kw
    Hull Extension, Chines and Hardtop
    This problem occurred when we had the 490. After making sure that there are no blockages using a snake, we blocked the through-hull for the drain line and added a hefty dose of Zaal Noflex Digester and topped up with water. It took a couple of treatments, but it cleaned up all of the odors in two days.
    https://www.marinesan.com/Noflex-digestor-p/noflex.htm
    Rob
    Bayliner 5788
    'Merlin V'
    Vancouver BC
      Is there anyway to reroute it or raise the thruhull? On my 32xx it was a very short and all downhill run, so no way for water to get trapped anywhere.
      Esteban
      Huntington Beach, California
      2018 Element 16
      • MerlinV
        MerlinV commented
        It would be difficult to change the drain line without much reworking. I think one of the main issues here is that there are 2 sinks in the galley, and the cross tube between the two drains gets gunked up fairly quickly.
      Great suggestion. As luck would have it, I just got 4 bottles of Noflex last week to use in the holding tank. I'll give this a go! What did you use for plugging the thru-hull?
      James
      Gig Harbor, WA
      • MerlinV
        MerlinV commented
        I used aluminum tape - the really awkward stuff where the backing has to peel off. It adheres really well to itself and almost anything else where there's no oil or grease present
