I just purchased a new steering Console Walker Bay 10 1/2 foot RIB dinghy. My old Achilies RIB was 9.2 feet and with motor weighed under 200 pounds. I have a home made type davit system, it consists of two stainless steel half circle davits through bolted on the swim step and a Weaver Wench rated at 400#'s on the fly bridge. The davits have a rope attached on each that you cross underneath the dinghy and apply pressure to each end while lifting the dingy.
With this set up I needed two people to lift the dingy. So in each corner of the fly bridge I installed a Swivel Cam Base http://www.westmarine.com/webapp/wcs...5#.UBLc0qPdfYg which allows me to pull the lines tight and work the wench while standing on the fly bridge ladder eliminating the need for a second person.
The new dinghy is going to weigh in at about 400# and I am hoping my current system will suffice for the time being. I take delivery of the new boat next Wednesday 8/1/2012 so I will not know if my davits can handle it or not until then. I have done my research and I think I have a decent chance of my current system working. If it does not work I am having bottom paint put on the dinghy so I can leave it in the water while I work on a new davit system which leads to my question:
What is the best davit system to put on my 38's swim step for a 400# console RIB? Ideally we would like something under $2k and small enough that we can still sit on the swim step while moored up, we like to get some sun with legs in the water or go for swims and climb back up the ladder. So I guess what is the best bang for the buck on davits? Any suggestions, comments, reply's would be appreciated.
