I have a couple projects on my list and one is to reduce the amount of noise the potable water pump is making. It cycles a ton which I know I could reduce with a pressure accumulator. I'm curious if others find their pump very noisy and what if anything they have done to fix it. We have our 10 week old sleep in the guest stateroom and the noise from the pump is waking him up.
Also along the lines of the locker cutouts many 3988 owners do along the sides I was thinking of doing something similar on the inside of the back of the transom. Anyone know if this would substantially weaken the transom? Has anyone done this?
Eventually we want to get a center console aluminium AB dingy with probably a 40hp motor. I am assuming with a center console the dingy would need to be mounted upright as opposed to on its side. Ideally we would like to keep the swim step as open as possible while at dock. Do people have solutions they recommend or don't recommend?
On the long list of little things to do is add a AC outlet on the flybridge, more 12v outlets in the salon, storage cabinet behind the starboard engine, replace the blinds at some point.
Does anyone know if there is a way to access the area under the salon seating next to the lower helm. There is a drawer under one seat but the other seat seems like it should be able to have storage under it but no easy way to access it.
Thanks for any help,
