3788 vinyl covered side panel removal question
    Has anyone removed the side panel in the galley? I need to install a propane leak detector in the panel and route the wire through the cabinet below to the galley floor. It looks like several screws hold it in place. Could it be just that easy?
    Tony Bacon,
    Washougal, WA
    Caspian
    1997 3788 Twin Cummins 250hp
    I have taken the opposite sides panel off. It was held by the screws. For me it was a bear to remove as its tightly wedged in there. Lots of “giggeling” if that’s a word to get it out. Assuming same for galley side.
    2014 Sea Fox 22 Center Console
    2006 Boston Whaler 13 Sport
    Vero Beach, Fl.
      Yes, giggling is a word, but you were probably doing more jiggling and cursing than laughing. (sorry....couldn't resist).
      1998 BL Ciera 2655 Sunbridge LX (Special Edition)
      "Sea Flights"
      5.7L 2bbl w/Thunderbolt Ignition
      Alpha I Gen II Sterndrive with raw water cooling
      MFG Extra's - A/C, Fresh Water Engine Flush port, HWH and Windlass
      Docks @ Punta Gorda, Florida
        Thanks. I was puzzled that there are screws along the top but not the bottom. I will venture forth when I return to the boat now that I am better psyched.
        Tony Bacon,
        Washougal, WA
        Caspian
          On my 3870 I removed the drawers and fed the wire through from the stb helm.
            My 3888 vinyl panels had a few screws, some of those plastic car interior ribbed rivets (you just pull the panel off if your brave enough to try it) and some had some glue in addition to the screws. I seemed to be factory but I'm the 3rd owner.
