Fuel System Bonding
    Fuel System Bonding
    I am replacing the factory installed Dahl primary fuel filters with Racors. I have wires connected to the filter housings that go to the bonding system. The filters are mounted on plywood on the front engine bulkhead and are isolated by rubber fuel lines. I have not seen filters connected to the bonding system before. I was planning on removing this wiring- Am I missing something? It does not appear to be factory installed wiring. Maybe the PO was confused? Anyone else have this on their primary filters?
    Gibraltar, Mi.
    1986- 3870- Hino 175's - Just purchased May ,2017
    34' Tollycraft- sold
    88 26' Shamrock/ Diesel
    14' Zodiac Bay Runner
    I am guessing that the fuel is a conductor even though the hose is not.
    Tony Bacon,
    Washougal, WA
    Caspian
    1997 3788 Twin Cummins 250hp
      Sounds like a belt and suspenders approach to me. Diesel isn’t an electrolyte to my knowledge, therefore, protecting dissimilar metals isn’t an issue. Sorry Mrs. Dennis, although I remember more from you chemistry class than I thought I would, I’m sure I missed that part.
        ABYC H-33-6 states that metal deck filling components must be bonded. There is no mention of bonding being required for diesel fuel filter housings
        Stan
        2001 Bayliner 4788
        Underhulls
        Bow & Stern Thrusters
        Hydronic heater
        330 Cummins
          this is correct... the metal deck fitting must be bonded to insure that any static is discharged before fueling... diesel or gas doesnt matter, its a "blanket" coverage rule...
          the filters have no need of being bonded, as either they are insulated from, or directly connected to the engine, but either way no electricity or stray current is "passing thru" them....
          NU LIBERTE'
          Salem, OR
          5.7 OMC Cobra - 15.5x11 prop
          N2K equipped throughout..
            What is the harm in having them connect since the wiring is already there?
            Mark
            USCG OUPV
            1990 4588
            Carlsbad, CA
              No harm at all in my opinion
              Stan
              2001 Bayliner 4788
              Underhulls
              Hydronic heater
              330 Cummins
                there is no problem until there is a problem... the filters are isolated, but as they are now bonded, if at any time, there is any stray current develops, it may take current to the filters which otherwise would remain isolated.
                when one ponders the Risk vs Gain, you will see the risk is small, but either way you look at it, there is absolutely NO gain by having the isolated filters bonded.... just another wire to add to the spider web of wiring in the boat...
                kind of like bonding all your deck hardware, its unnecessary.
                NU LIBERTE'
                Salem, OR
                  Centerline has a a very good point. Keeping the boat simple has sooooo many advantages over adding stuff that is not necessary.
                  Stan
                  2001 Bayliner 4788
                  Underhulls
                  Hydronic heater
                  330 Cummins
                    I suspect you shouldn't want to create an alternative path for stray current if the intended bonding were to fail (or for any other unknown reason).
                    1988 3888 "Liberty"
                    Twin Cummins 6BT's 210hp
                    Onan 8.0
                    Boating Raritan Bay
