Exhaust water discharge
    Hi there,
    this spring we are going to take posession of our 3587, and as had been suggested upon startup it is wise to take a look at the exhaust output to insure cooling water is flowing however the exhaust output is below the waterline. Any suggestions or thoughts on this are appreciated.
    dean
    You should be able to see the flow as a current in the water.
      Seems like the engine combustion could create turbulence in the water even without the cooling water discharge.
        It depends largely on the mufflers. If they are a type that fill then the exhaust pushes the water out, that’s pretty obvious. Same of the outlet is an inch or two above the water. With my 3818 having the extended hardtop, my ports are an inch or so into the water making it a challenge to see sometimes.
          Stand on corner of swim step and have a buddy look for flow on other side.
          Started boating 1965
            Tried that, didn't tilt much.
              Put a bit of Dawn in the intake...?
              1988 3888 "Liberty"
              Twin Cummins 6BT's 210hp
              Onan 8.0
              Boating Raritan Bay
                This has to be a joke. I hope your not serious.
                1999 Bayliner Ciera 2655
                5.7 Bravo 3
                  Get several friends on swim step side
                    Tie a small strip of cloth onto your boat hook and put it next to the exhaust port in the water. The strip should wave in the current.
                      This is pretty simple. Let it run for a few minutes and reach temperature. Buzzers will tell you real quick if there is water flow.
                      CPT.BLAIR
                      1993 4387 w/ 250 Hinos - Hampton, VA
                      1996 3388 w/ 150 Cummins - Richmond, VA
                      1989 Sea Ray 390 w/454 Mercruisers SOLD
                      1983 3288 w/ 3.8 Chevy V6 gassers SOLD
                      1984 3870 w/ 135 Mits SOLD
                        Serious...I have used Dawn to lube impellers when I put them back in the Spring...yes, it makes suds for a bit...would be a tell tale...
                        1988 3888 "Liberty"
                        Onan 8.0
                        Boating Raritan Bay
                          Lol, I really am not trying to be difficult.
                          Was just hoping there was a easy way to confirm water flow as part of a pre-cruise routine. As being new to boating just want to feel confident as I leave the dock. Thinking it might be worth having new pump impellers installed. I really want to avoid as many issues as possible so that the new boat experience is as fun as possible. Another big concern which we have no control over is potential high water in Lake Ontario.
                            Understand the "anxiety"...I too am picking up a new (to me) 38 and before I leave Baltimore I will be putting my maintenance items at "zero"...inspect and change as necessary (impellers, filters, strainers, oil, coolant, generator and trans fluids...then I can breathe easy...
                            My pre-cruise prep is always fluid levels, water flow, engine temp, oil pressure, gauges, etc...then take off for points unknown. I will be preparing a short list to work from until it becomes second nature.
                            Did not understand you original question...thought you were talking about FIRST excursion...my bad...
                            Regards, Nick
                            1988 3888 "Liberty"
                            Onan 8.0
                            Boating Raritan Bay
                              Well it is our first ever boat, every aspect is a first for us at this point.
