What Year Did Bayliner Stop Balsa Use
    When did everything switch from balsa to foam core.
    Started boating 1965
    I believe the use of balsa was more dependent on the boat design than the year. I say that, as my previous boat, a 4588, had a balsa core, but I remember the newer body styled smaller bayliners of the time didn’t. The Bayliner 4588’s were built from 1984 to 1993 when then redesigned the boat into the 4788 and eliminated balsa (among other things), as I understand it. I guess the question is, is there a boat you were interest in and curious if it has balsa? That might be an easier question to answer...
    i hope that helps...
    BJ
    OMEGA
    5788
    BJ
    OMEGA
    5788
      They still used balsa on 1996 3988’s.
      1996 4087 Lazy Days
      2011 Porsche Cayman
      2010 Lexus IS 250C
      2008 Honda Ridgeline
        did they ever? there would be a lot less soft deck boats around today had they used foam on the decks.
        I have a foam cored, even the transom, power cat bay boat at our Florida place , it has open holes in the deck, I sunk it, beat It, and abused it. no rot 18yrs old. if it was wood cored more than likely be junk.
        1988 3270
        135 hinos
        Seldovia ALASKA
        KEVINS UPHOLSTERY
        KEVINSBOATTOPS.COM
        Marine canvas/Upholstery
        since 1975
