Hello all, I am hoping for comments / opinions on the most correct way to layout negative cabling for an inverter charger / smart shunt on my 2001 3988.
I have added an alternate layout option hoping for opinion on which is better, or if either layout is fine. I believe the feedback re alternators could be connected to house bank and then combined to start banks is possibly a good idea, although with stock alternators I would worry about them over working (heating). The boat is equipped with an 8kw gen, so the current layout helps a bit toward charging house while running, but house is mostly charged by generator.
I have read extensively on the forum and the vault section (re shunts) as well as my Nigel Calder manual, and inverter install manual, but I still come away with some uncertainty. I have attached a portion of the modified electric schematic. I have drawn in the Inverter / Charger and smart shunt as well as two Charge Relays (combiners). I have placed the I/C and shunt into the electric layout as designed by Bayliner. From house bank DC negative to shunt (batt. side) and then I/C into shunt (load side) with DC negative to the Engine Block 'system common' and from there to the Main DC Buss Ground.
On some of the Vault thread layouts; The house bank DC negative would go to shunt (batt. side) and then I/C into shunt (load side) with DC negative running to the Main DC Buss Ground, and a separate cable from the Engine Block 'system common' to the Main DC Buss Ground as illustrated in the additional layout.
I am unsure if the way I have drawn this makes the engine block 'system common' current carrying?
The inverter company recommends the Chassis ground should connect to the engine block 'system common'. This brings me to questions regarding non current carrying DC ground, DC negative buss, and AC ground buss. Should a 12V non current carrying Chassis ground (for any 12V appliance/electronics) connect to the current carrying Main DC Buss Ground (that is the DC negative buss) or the non current carrying AC ground buss where all AC appliance grounds connect as well as the bonding conductor, and then a single cable connects this to the Main DC Buss Ground.
Any clarity will be greatly appreciated.
Cheers
Rick
Attached files [img]/media/kunena/attachments/vb/651222=25200-I:C DC layout option 2 zoom.jpg[/img]
