Door weather stripping
    I am trying to locate the weather stripping for the salon slider door. The door has a channel on the trailing edge (starboard side) on the inside. This channel runs the entire height of the door. It stops air flow between the door and aft bulk head. I have attached pictures of the profile.
    Does any one know where I can purchase this weather stripping?
    Trailing door edge on the inside. Better pic
    You might check out ultrafab.com. They make a ton of various weather stripping types...
    i hope this helps,
    BJ
    OMEGA
    5788
    BJ
    OMEGA
    5788
    This is where I got mine. its in Denmark (i live in Denmark) but this guy got all sort of striping. Just ask him - he will get. I think postage is limited since it fills an envelope.
    https://www.profillageret.dk/boerste...rsteliste.html
    Brgds.
      I just bought some from this place: https://slide-ezzz.com/
      Tony Bacon,
      Washougal, WA
      Caspian
      1997 3788 Twin Cummins 250hp
        do a web search for.... fuzzy pile weather stripping .... look at "images" and you will have lots of options to choose from.
        NU LIBERTE'
        Salem, OR
        5.7 OMC Cobra - 15.5x11 prop
        N2K equipped throughout..
        • scubadiver3988
          scubadiver3988 commented
          Thanks for the heads up. Found the stripping near Seattle WA. Comes in 11,000 ft. roll but owner cut 10' for me.
        What sizes do we need for the salon door?
        New to me 1998 bayliner 3988 Cummins
        • scubadiver3988
          The door (mine) has only one size and style. The size is 3/8" pile and push in style. The door jamb (mine) has one style and two sizes. Facing the door from the cockpit, the forward pile is 1/2" x 5/16". 1/2" is pile length; 5/16" is backing width. The aft pile is 3/8"; the backing is 3/32".
        Turns out the stripping I ordered is not the correct type. Mine is completely missing and I wrongly assumed it was the same type as that which is in the jamb. I need the same kind you used. Can you tell me the depth of the pile?
        Tony Bacon,
        Washougal, WA
        Caspian
        • scubadiver3988
          Pile depth is 3/8". Backing looks like an arrow with two fins. I will try to attach a drawing but don't hold your breath.
        • scubadiver3988
          Still can't figure out how to attach pics to this website. Blue bar just keeps blinking.
          If you send an email address, I can forward a pic. shipmate3988@hotmail.com
        Thanks scubadiver. I saw the pictures in the original post. I am sure that is what I need. I had purchased they type that is T shapped and slides into the groove. The trouble with that is that the grouve in the door is deep enough to swallow the whole thing.
        Tony Bacon,
        Washougal, WA
        Caspian
          The google search to use is KERF Mounted Pile Weatherstripping. This turns up a number of suppliers, some that sell by the foot.
          Tony Bacon,
          Washougal, WA
          Caspian
            i placed an order. hope it all works out.
              Here’s another good site: https://www.swisco.com/cl/Weatherstripping
              Jim Gandee
              1989 3888
              Hino 175's
              Fire Escape
              Fyrflyer@ca.rr.com
              • MacPhid
                MacPhid commented
                Jim, thanks for the link! I’ve been looking for the aluminum track for our sliding entry door, they had some options to consider.
                James
              Glad to help out James!
              Jim Gandee
              1989 3888
              Hino 175's
              Fire Escape
              Fyrflyer@ca.rr.com
                Has anyone tried this sliding door repair kit? I am tired of replacing my wheels and this looks like a good solution if it will work on a salon door.
                2000 Bayliner 4788 "Perfect Balance"
                370HP Cummins
                Zodiac YL 340 30HP Nissan
                Moored at Roche Harbor
