38xx hino buzzer buzzing!
ID:	411585 I changed my engine oil/ filter yesterday.
    On my starboard motor, after changing it the engine buzzer did not cut off after start up.
    Oil pressure good and temp low.
    I changed the oil pressure sensor just in case as it looked rusted and oil.
    When I remove the lower lead (in pic below) the buzzer stops.
    What is lower lead for??
    thoughts??
    Craig
    Nanaimo bc
    1987 bayliner 3818
    w/ 175 Hinos no Genny, but solar to run everything!
    10ft Livingston with centre console and 15hp on davits / winch
    It looks like a sending unit on one hand and a cap with a stud on the other. I can’t find it on the parts schematics or wiring schematics such as they are. The buzzer switch and pressure sending unit are separate. On mine the buzzer switch is the one on the near side pointing kinda toward the camera. I’d go look at my boat, but we are a few thousand miles away for a while. You could test it as a ground, which is what I think it is, by clipping a test light to the stud and touching the hot line at the alternator, then doing the same thing with the wire disconnected, then the clip on the wire only. It could be you pressure alarm switch decided it was done. Let us know what you find.
      What Pete said...
      was the lower wire you removed 16AWG GREEN wire? If so, that is the ground path (12VDC -) for the buzzer.
      buzzer 12VDC + PURPLE wire comes from the ignition switch/ gauges.
      buzzer 12VDC - GREEN wire comes thru the NORMALLY CLOSED oil pressure switch.
      continuity/ohm tester will tell right away.
        The switch facing the camera and farthest to the right is the switch. The pressure sender is just that a variable sensor. I broke the buzzer sensor taking the manicooler off and I'm pretty sure it was from a 70's vw bug I think. Brought the thing to Oreillys and the matched thread pattern then cross referenced. Was maybe $4
        1985 3870 175hp Hino's
          Here is my take on this the lowest single wire item is filter by pass with that said I bet you installed filter backward that is why alarm stayed on after start up
          just thinking out loud best of luck
          Roy
          SE Alaska
          1988 3818
          EH 700
          Custom hard top enclosed
            Roy
            SE Alaska
            Good call!
            was wondering what that thing is at the bottom.
            if that's the filter bypass sensor switch, makes sense.
              Makes perfect sense. I wonder why it doesn’t seem to show up on the electrical components microfilm. I found the darn thing on the oil filter slide. WTH? (Family show here)
                Ruffeyder.
                will pull filter to see. Did not think that would be it since the pressure on the gauge is good..
                Craig
                Nanaimo bc
                1987 bayliner 3818
                  EMBARRASSING!
                  Roy, you were right. I somehow put the filter in backwards!!!!! That was causing the alarm. Weird that the pressure on the gauge was ok.
                  Thank you!
                  Craig
                  Nanaimo bc
                  1987 bayliner 3818
                    The bypass will allow oil pressure, but chew your a$$ for having a clogged filter.
                      Yup, by pass valve open, unfiltered oil going thru
                        No worries glade it all worked out enjoy your boat
                        I just finished two buddy helicopters time for me to move to my boat
                        cheers
                        Roy
                        1988 3818
                        EH 700
