4788 Head Raw Water Pump Location? (1997 Jabsco Quiet Flush)
    The breaker feeding the raw water pump for the heads is tripping. There is clearly a short somewhere.
    There is only one breaker for both heads for water feed.
    I know where the two water solenoids are inside the sink cabinets. The short may be in there.
    Where is the raw water head feed pump located in the boat?
    Was anyone changed to fresh water flush?
    Thanks,
    -Morgan
    2004 Meridian 580 "Mostly Harmless"
    1997 Bayliner 4788 & 1990 Bayliner 3888
    Morgan, I believe the raw water feed pump is behind/beside the built in vacuum, accessed through the hallway smoke glass sliding doors.
    "Allante I" Rayburn 75
    Previous: '97 4788
      Thanks White Rock Mike! Found it. I have a bus heater mounted in front of it. The motor was bad and shorting out. What a #$%# to get out. It's going to be even more fun to install the replacement.
