Flybridge electronics fuses?
    The electronics (GPSMap and fishfinder) on my flybridge won’t power on and i suspect one or more blown fuses. I have a couple of electrical schematics for the 1987-era 32-footers; one shows a minimal fuse panel for the upper station, the other shows only wiring on the upper station with all fuses behind the lower helm console. Can anyone tell me if I should look for a fuse panel under the upper console (or somewhere else)? I’ll be going to the boat tomorrow and I’m hoping to get a head start on diagnosing the problem.
    Dick
    Cheers
    Oceanside
    1987 3218 w/ 150 Hinos
    There should be a fuse panel in the upper helm behind the wheel. I was having connection issues with mine and replaced it with a BlueSea 12 circut panel and no more issues. I was also a good opportunity to clean up wiring and label the circuts.
    "Martini's Law" SOLD
    Nova Scotia, Canada
      It turns out that the problem was wiring; a ground wire corroded and went adrift. Thanks to diveguy I did find the fuse panel. With a bit of wiring cleanup my electronics are working again.
      Dick
      Cheers
      Oceanside
