5788 Window Valances
    We are in the process of replacing the window coverings on our 5788. As a part of this process we would like to change the fabric covering the valances above the windows, but can't figure out how to remove them. I figure that there must be a sequence of removing the various vinyl covered panels to access the mounting screws for the valances, but so far, no success.
    Has anyone any idea how these valances can be removed?
    Rob
    Bayliner 5788
    'Merlin V'
    Vancouver BC
    The valences on the 4788 are screwed upwards to the ceiling inside the valence and the screws/fender washers are quite visible once the window coverings/blinds are removed. Not sure if they used the same method on your more recent 5788.
    Alan Teed
    MOONSHADOW
    1996 Wendon Sky Lounge 72'
    Gig Harbor, WA
    Previously:
    1994 Bayliner 4788
    2006 Hylas 49' SY
    Bayliner 2855
    1977 Cal 34' SY
    1981 Hunter 33' SY
      Hey Rob,
      Funny you are working on your valences... I just was talking to another friend in Tacoma that is redoing some of thier 5288 interior and they ran into a snag with removing the valence panel’s... they found that the valence required a lot of dismantling of the interior to get them down to redo. Instead of pulling my valences apart, I decided to simply make Roman shade type covers that were installed it’s Velcro and removable.. they ere way cheaper and seemed to do the trick...
      ~BJ
      BJ
      OMEGA
      5788
      • Alan_Teed
        Alan_Teed commented
        The Roman shade covers look great! I take back my comment above since clearly the 5788 valence arrangement is very different from the 4788! I am pulling my valences off and replacing with slimmer teak panels.
      Alan's right, those Roman shades are outstanding - what a great idea. This will be one of the upgrades that will totally be in the hands pf the Admiral.
      Rob
      Bayliner 5788
      'Merlin V'
      Vancouver BC
        Thank you for the kind words.... it took me a bit to get things just right,but I think it worked out pretty well...
        as a side note,I made them just a shade narrower than I wanted them and stretched them ever so slightly after I ironed them, so they would lay how I wanted. The other advantage I like about removable valances is that I can change them fairly easily in the future If and when I want.
        I look forward to seeing your new valences...
        ~BJ
        BJ
        OMEGA
        5788
          Your valances are awesome and what a great idea! We just purchased the 5288 and they have fabric on them already so I'm thinking of trying this on mine. I need to figure out how to attach them though.
          Jacqueline Z
          Cassiopeia
          1999 Bayliner 5288
            Originally posted by igiftmon View Post
            Hey Rob,
            ~BJ
            That is a Fantastic way to spruce up the window area!!!!
            I could sew those up really fast!
            Actually I’m going to Sailrite.com right now and ordering some material!
