5788 A/C panel wire routing
    Curious if anyone has tried routing wire from the A/C power distribution panel in the pilot house to the engine room or other location. I’ve dismantled the panel and run into walls at everything I tried. I’ve looked under all the areas from under th stairs, but there appears to be fiberglass bulkheads in the way, I can see the routing as the wires enters the area below the panel, but theres so many wires, they don’t flex easily to follow into the abis of th wall...
    My next step is to use a bore scope to look around behind the wall,but any ideas you may have would be great...
    Thanks,
    BJ
    OMEGA
    5788
    BJ
    OMEGA
    5788
