4788: AC plugs
    4788: AC plugs
    My 2 plugs on the bar quite working all of a sudden. The other 5 plugs (salon and pilothouse) on the breaker are working. I reset all gfi outlets including the one in the bar on the flybridge. For the life of me I can’t figure out wjy these two plugs just stopped working. Thoughts? Thank you!
    Jamie
    1997 4788 w/Cummins
    Boston Whaler 110
    Those are controlled by the GFCI outlet just to the right of the stove I think
      I reset all the gfi’s. I believe the bar outlets are port side outlet in the pilothouse.
      1997 4788 w/Cummins
      Boston Whaler 110
        GFCI receptacle itself can go bad, fail...
        oftentimes, GFCI not tripped, but no current downstream.
        See if you have voltage on the line side of the GFCI, but no voltage on the load side of the receptacle.
          Are gfci usually at the end or beginning or a string of outlets? Or does it matter?
          1997 4788 w/Cummins
          Boston Whaler 110
            GFCI's are at the beginning of the string of outlets. Anywhere else would require extra wiring.
            Kevin
            Seattle
            'Joysea' 1998 3788 MY 270 Cummins
            My 6th Bayliner
              does anyone have knowledge to of the wiring for the Salon/Pilothouse AC wiring? Since the GFI Plug is port side pilothouse I know now that is plug 1/7, I assume the plug starboard PH is 2/7. Where does it go from there? The Galley or the bar? My problem is the two plugs at the bar stopped working but all the other plugs on the line work fine.
              I know that the plug by the bar sink is the end of the line and the plug portside aft is also the end of the line.
              Any thoughts will greatly be appreciated.
              Jamie
              Alameda, CA
              1997 4788 w/Cummins
              Boston Whaler 110
                I have a similar problem, the GFI at the counter beside the stove works and the outlet by the salon door works but no others. Also none of the stateroom outlets work, There is power on both sides of the AC panel circuit breakers. I will be troubleshooting it this weekend and it sure would help to know the sequence the witches are wired in. The schematic I have fron the 4788 owners supplement shows the circuit breakers but nothing downstream of them.
                2001 Bayliner 4788
                Underhulls
                Bow & Stern Thrusters
                330 Cummins
                Moored: Captains Cove Ladner BC
                  Since it's a looping system,
                  check the receptacle prior to your bar outlets, most likely fault is there.
                    Found some info that may help
                    120-volt Outlets
                    120-volt outlets are ground-fault protected (GFCI). In an outlet is not operating, first check the AC panel receptacle switch, and then check the GFCI outlet for the circuit
                    [IMG]file:///page20image3767984[/IMG]
                    Receptacle Switch Outlet Location GFCI Location Suggested Usage
                    Salon/Pilothouse Port Side Helm Portside Helm
                    Salon/Pilothouse Starboard Side Helm Portside Helm
                    Salon/Pilothouse Above Stereo Portside Helm Cell, iPod Charger
                    Salon/Pilothouse In-Front Stereo Portside Helm Cell, iPod Charger
                    Salon/Pilothouse Salon Beneath Sofa Portside Helm Laptop Power Cord
                    Galley Stove Starboard Stove Starboard Coffee Maker
                    Galley Sink Counter Stove Starboard Small Appliances
                    Galley Salon Stb Aft Floor Stove Starboard Laptop Power Cord
                    Galley Pilothouse Aft Seat Stove Starboard Laptop Power Cord
                    Aft Stateroom/Head Aft Head Cabinet Aft Head Cabinet
                    Aft Stateroom/Head Aft Stateroom Aft Head Cabinet
                    Forward Stateroom/Head Fwd Head Cabinet Fwd Head Cabinet
                    Forward Stateroom/Head Fwd Stateroom Stb Fwd Head Cabinet
                    Forward Stateroom/Head Fwd Stateroom Port Fwd Head Cabinet
                    Flybridge Refrigerator Beneath Sink Cabinet Sink Cabinet Dinghy Battery Charger
                    2001 Bayliner 4788
                    Underhulls
                    330 Cummins
                      There's another GFI receptacle for the washing machine/dryer. Not sure whether that is the problem. For access, lie on the lower bunk, and open the small access cupboard door behind the dryer....
                      cheers
                      John H
                      Brisbane QLD Aust
                      "Harbor-nating"
                      2000 - 4788/Cummins 370's
                        Update. Outlet PH starboard side was toast. Replaced. Issue fixed. I do not know what caused it. The Keurig is downstream. I am surprised that the outlet was still functioning.
                        1997 4788 w/Cummins
                        Boston Whaler 110
                          An appliance that draws too much wattage like a portable heater, coffee maker.
                          Keurig in your case, peak draw is about 1500W app 12.5 amp.
                          Is that branch circuit on a 20amp breaker or 15?
                          Very dangerous situation... you dodged a bullet.
