This subject came up on another string so I'm starting a new one for input.
PIKA STEVE posted that on a previous boat he had a winch mounted in the laz for towing his tender.
I bought a winch a few months ago with this in mind.
Has anyone else done this? If so please share your experiences and how yours is set up.
Chris
Originally Posted by pika steve
I used this setup on our 38 foot tug as well, but had a small winch mounted under the rear deck, with amsteel rope. This rope exited the hull just under the stern bumper rail. The winch was equipped with a wireless remote so when docking I could winch the tender into the boat until I felt it bump up against the stern rail of the tug. That was a sweet set up. You did not even have to get your hands wet to pull in the 19 footer! I have been thinking of installing one (winch in the lazz) on our present 4588. Great setup for a stern anchor, shore tie, or tender hauling.
Cheers all. Steve
(Hijack)
Steve this is great timing, I was just engineering a setup like you're talking about. I bought a small 12v winch and intend to set it up for towing. Do you have any details or photos of your old setup?
Chris
sorry I don't have any pictures of the winch. Just used a 12 volt 4x4 type winch and replaced the cable with amsteel. Bolted her down and used a piece of 3/8 copper tube with a nice flare, driven in and glued into the stern rail. All the line was under deck and a straight pull to the drum. The distance to the drum was 10 feet, and it seemed to feed on evenly, perhaps because of that long distance. Why don't you start up a thread and get the thoughts of all interested parties? I like the idea of going through a roller once the amsteel goes through the thimball you will need to install in the transome (for instance)
Steve
Chris
Cheers all. Steve
(Hijack)
Chris
Steve
