Im a little confused!
My wife went to the boat early this morning to pick up something and she called me. "Honey you better come quickly, the boat is taking on water".
I got there and thank God it was'nt as bad as I envisioned on my 2 minute ride there. What a horrible 2 minutes!
The companionway had about 6-8 inches of water sloshing around, just above my 12x12 pop in teak floor panels(which I've never seen before). They were kind of floating.
Water also in the aft stateroom floor.
Now I know both water tanks are empty, so i ruled them out. It has been 5 days since I was last at the boat and we did get 3 days of rain for an hour or so each day.
Are the 2 drains on each side of the pilothouse exiting directly out the hull? I would imagine they are. Or I should say, they "should be".
Normally the bilge pumps would come on automatically, "without" the battery switches being on, but I guess they did'nt.
I turned on the switch for the house battery and they came on and in 10 minutes pumped the water out.
I checked the engine compartment and saw just an inch of water under the engines. it seems to me that if the compwy gets high enough, the water would seep over from forward.
Also, i tasted the water, as carefully as i can and it was fresh water. Thats good, since we are in the salt water.
So I'm stumped!
Any ideas???
Ed
So I'm stumped!
Any ideas???
Ed
