Two weeks of hell continues while I should be OTW to Desolation Sound
Very long and frustrating story but here is the latest info. Got major amount of water in both fuel tanks. It was either vandalism or bad diesel from the fuel dock I bought the last 400 liters from.
Polished all fuel....didn't help.
Pumped ALL ~300 gallons out (into barrels) and refilled with new diesel.
I have both engines drawing and returning to the same tank. Sea trial shook up tanks and port engine stalled again. Racor and downstream filters and flo-scan homoginizers were 1/2 full of water again. I emptied and refilled them with diesel and sat and watched Racor bowls as we idled around the bay.
The starboard racor has NO water in it and it is running fine. The port racor filled up so fast with water it overwhelmed the racor and stalled the engine again. I repeaded the filter process and sat in the engine room with the port engine shut off as we idled around on the starboard only. The port racor had water constantly dropping into the bottom of the bowl as I kept opening the valve to empty it (while not running the engine) and this continued for almost an hour as we cruised around on the starboard engine.I finally gave up.
Has anyone seen the inside of a 3988 fuel tank? Is it possible that the bottom of the port pickup is lower in the than the starboard pickup inside the tank? Are there baffles in the bottom of the tanks that would hold water in the rear (pick up) section of the tank after pumping the rest basically dry through the sender hole?
Is there ANY other place within the fuel system where water could get into it as described above.
Frustrated and perplexed!!
Deman
Deman
