Now that I have repaired the leak in our main water tank, and am able to use it, ( thanks for your ideas on that by the way) I find that the midship toilet overflows (and fills the entire bathroom with water) when the tank is full. As the level drops the toilet seems to take on the level of the tank. We have electric jabsco toilets. I am considering just adding a 12 volt normaly closed solenoid on the toilet supply line, so that water is only delivered when the pump is called, but thought I should ping this outrageous resource first. I suppose the bow toilet is higher so we don't see the problem there, but standing water level does rise a bit when the tank is full.
Any thoughts? Thanks Steve
