1989 3888 over table lights
    Does anybody have dimensions of the square brass ringed lamp that were originally installed? Probably also used in the 32 and 45 of the same vintage.
    Looking to upgrade and want to make sure the replacement is bigger than the original to hide headliner discoloration from time.
    Also looking for the eyeball lights under the anchor locker - salt air has rendered them basically junk and time to replace those as well
    Thanks in advance
    Nobody gets out alive.
    Sorry I can’t tell you what the original size was, but we have 9”x9” trim that hides any previous mounting holes. Hope that helps...
    Drew Haas
    1998 4788 "Painkiller"
      The fixtures are 7-1/4" square. We are also looking to replace them with a single fixture to cover the area occupied by both fixtures.
      1987 3870 "Stella Maris"
      Hino 175's
      Lanoka Harbor, NJ
      MMSI# 368141940
        That is what I was afraid of - I had a light in mind that was 6x6.
        It might mount to a block of teak tho...
          Thanks in advance
          I just bought these lights from home depot. My plan is replace the incandescent with 5 12v leds 1156 (automotive). The leds and sockets I ordered from Aliexpress in China for cheap.
          The lights are 9x9 and are called Appeal Collection 2-Light Brushed Nickel Flushmount
          1988 3870
          Hino 4 cyl 210 turbos (upgrade)
          Hull extension
          LIves in Powell River
