When I recently bought the boat, someone had changed the switch (circled) with not only the wrong switch, but one which doesn't even move to act as a switch. I'd like to replace it with a functioning switch like the two above it....any ideas on how to obtain the original part?
4588: AC Panel Switch
Hi Jeff
I actually replace that switch years and years ago I can't remember the manufacture and I'm nowhere near the boat at this time.I would suggest getting the manufactures name on the other two rotary switches and do a search.Maybe someone here can take a picture and show you the switch it is larger than the other two switches you pointed out.
Good luck Brad
