1986 3270, Engine hatch drain scupper
    On my 1986 3270, my engine room hatches have a drain scupper in the corner of each hatch trough area (area where hatch seats on cockpit deck). For the starboard hatch the scupper is located in the rear starboard corner. Does anybody know where these drain to? Mine is currently plugged and I am trying to clear it out. I have tried running a rod down it but it was too stiff and would not turn the corner to get to the blockage. Any ideas? Thanks.
    Keith
    1986 3270, twin 110 Hinos
    Olympia, WA
    There should be an elbow and a hose to an overboard fitting.
    Glen Sherwood
    1987 3270 twin 305’s
    Coupeville, WA
      It goes out through the transom just below the swim step.
      Jim
      1988 3270 With 135 Hinos
        FWIW, if the OEM drain hoses are still being used consider replacing/upgrading them, they can become very brittle over time.
          Jim
          +1
          CapMartin, Montreal QC
          "Belle de Dalhousie"
          1986 3270 SOLD
          Volvo BB225B
            I recently replaced all my hoses. The area you mention has an elbow and a wye as it picks up the deck drain and the hatch drain (as I recall before) it exits the transom just above the water line.
            Rick
            2002, 3788
              On my 3870 those drains seemed to plug up all the time. I just bought bigger hose and fittings to change the system over to 1 inch. Will find out next summer how much this helps.The old hoses were extremely hard and ready to crack.
              Gibraltar, Mi.
              1986- 3870- Hino 175's
              1988 26' Shamrock/ Diesel
              14' Zodiac Bay Runner
                I recently had to replace my hoses and connector at the Y joint because it had broken on my Avanti 3255. Wild_Blue_Yonder is absolutely correct here. My drains luckily enough still have the grates over them but I'm considering what Sunbird is saying about clogs now. May have to consider that upsize.
                1987 Bayliner Avanti 3255
                Twin OMC 5.7L 4V
