air filter
    air filter
    The filter element on my air filters to my hino 150s are falling apart and no one in my area seems to have an answer as to what to use or where to get new.
    So here I am asking the boc members who have been through this
    What have you used for filter elements? unit is about 5 1/2" diameter by about 2 1/2" wide
    Maple Bay Yacht Club
    1990 3288 "Allure" w/150 hino x 2
    2004 Campion 622 fish killing machine "Knucklebuster", 150 yammy 4 stroke
    You're lucky. They are just up the Island highway: https://www.marinepartssupply.com
      Have you considered going to K&N’s? I have them on my 175’s and they are great.
        I just put K and N filters on my 135’s. Ordered them on line from K&N $56 with tax and shipping. Gone are the foam stips around the edge of the filters that collect oil and leave a nasty stain on the side of any shirt or coat I wear in the engine room. K&N say they will last up to 1 million miles. RA-0650. One of the reasons I changed out the OEM filters was the corrosion on the screen. If that scrren failed, it would go straight into the turbo and trach it or the engine.
        Jim
        1988 3270
        1988 3270 With 135 Hinos
          Thanks for the replies folks. Looks like I'm going with the K&N
            Can anyone tell me the part number for the K&N filter for the naturally aspirated Hino 175? I'm 1100 kilometers away from my vessel so can't do the measuring needed to ID size, I would like to order one or two before heading back to the vessel this spring? Thanks
            16' lap straight with B&S inboard, my 1st commercial fishing adventure
            17' run about with original 80ph Volvo, fun with some exploration of the coast
            25' Chris Craft - lots of fun exploring further north on the BC coast
            32' wood commercial salmon troller - ice boat, hard work & fun
            41' wood commercial salmon troller - ice boat, hard work & fun
            38' Permaglass commercial salmon troller - freezer boat, harder work & fun
            1987 3870 with 175 Hinos - back to mostly fun again & exploration
              RU 0960 is the K&N P/N
              cheers Roy
              SE Alaska
              1988 3818
              EH 700
              Custom hard top enclosed
              • Steadfast70
                Steadfast70 commented
                Roy Thanks for the information.
                John
                Powell River BC
              So I recently purchased the K&N RA-0650 filters to replace the factory air filters on my 110 hp, naturally aspirated Hinos. Looking at the stock setup, there is a hose coming from the stock air filter housing that goes to the fuel/water separator unit that is mounted on the motor. What do you do with this hose if you change out the stock air cleaner for the K&N? Thanks.
              Keith
              1986 3270, twin 110 Hinos
              Olympia, WA
                K&N has fittings you purchase seperately for that. Different sizes available. Look an their website under flame arrestors.
                Doug
                496 big block - Bravo ll leg
                The Doghouse
                Prince George BC
                  Do diesels have flame arrestors? I thought that was for gas motors only that have carburetors.............
                  Keith
                  Olympia, WA
                    The website shows a plastic 90deg fitting with the RA0650 filter. They have many different types of fittings for different applications.
                    Doug
                    The Doghouse
                    Prince George BC
                      I would recommend S&B Filters: https://www.sbfilters.com/ over the K & N brand. S&B uses silicon rubber, which is much better than urethane rubber. The filters are better at protecting your engine and maximizing performance. Happy New Year!!!
                      2002 4788/Cummins 330s
                      SF Bay Area
                        sketch96,
                        Thank you. I see now the fitting that you are talking about and from the picture I can see where the 90 degree elbow attaches at the base. Completely missed it when I took a prior look. Guess this is where the hose would attach.
                        Keith
                        Olympia, WA
                          I just installed the 0650's on my 135's. There was no hose going between the factory air filter assembly to the water separator. Guess I better research this !
                          1987 3218 135 hp Hino's
                          Bremerton Yacht Club
                          '00 Road King
                            There is no hose coming from the water separator - there is a crankcase breather hose that is positioned right near the air filter element to reduce engine room slop.
