What is 4788 DC Accessory #2 "Head Water" Circuit???
    I've been tracing wires on our boat, and am puzzling over the DC accessory #2 switch.
    Accessory #1 is the flybridge fridge, and Accessory #3 and #4 were clearly added by a prior owner - and I have traced them out.
    But accessory #2 is a mystery. It is a brown/white wire with the factory wiring label tag saying "Head Water".
    But what on earth is "Head Water"???
    It is clearly part of the wire bundle pulled by the factory - do any other Bayliner 4788 owners have this? What is hooked up to your accessory #2 circuit?
    Help solve the mystery!
    Cheers,
    - Chris
    Chris & Cherie - www.technomadia.com
    "Y-Not" - 1999 Bayliner 4788
    "Zephyr" - 1961 GM PD4106 Vintage Bus RV Conversion
    Full-Time nomads since 2006.
    Now spending half of each year slowly doing the Great Loop in our 4788!
    Pretty sure it is for the head water pump for the std electric heads NOT vacuflush which was an option. It is in the 4788 owners manual....
    Brad & Michelle
    Jet & Maverick
    1993 3688 "the Kraken"
    Hino W06 250HP
    14' Avon RIB, 50hp Tohatsu
    Moored at Shelter Bay
    LaConner, WA
