Toggle switch
    Toggle switch
    I need to replace a toggle switch from my dc panel. It is CW1401WA. There are other toggle switches out there of course, but This one is smaller in size of all the other ones I can find. Does anyone know a direct replacement. Otherwise, I will just cut a bigger hole for a newer style.
    Bayliner 4387
    250 Hino's
    Good on ya for a part number, but is it an on off on or an off on? Rocker style or lever? A picture would be really cool. What I’ve found is with some of these companies once a design is changed they get rid of the paper trail for the old design. Bomar hatches are the worst. If you can measure the diameter of the mounting hole, you may be able to find a match by plain old searching. For instance: https://www.walmart.com/ip/Seachoice...&wl13=&veh=sem. This one, when I read the specs and description, requires a .46 diameter hole. Just an example.
      If you have the dimensions looking up online at places like https://www.parts-express.com/cat/switches/77 is a way to try to find a fit.
      Charleston, S.C.
