3988 Steering Ram Capacity
Not sure if this is what you need: Hynautic ram is model K-51 rated: The K-51 is a small ram with a displacement of 10.1 ci
Cylinder working pressure is 950 PSI. Proof pressure is established at 4500 PSI. Burst pressure is 7000 PSI. Cylinder output force at 950 is 1390 Lbs.
- Likes 2
I'm planning to install an autopilot on my 1998 3988, and need to match a steering pump to the size of the hydraulic rams. Does anyone know what rams are installed on these boats? I've had a look but can't see any specs on the ram itself.
I found a really useful chart of all the different manufacturers' pump options - just need to know what CI size I need now. http://octopusdrives.com/sites/defau...Comparison.pdf
Any help greatly appreciated.Tags: None
