Question about 3270 bathroom liner.
    Hey all,
    Currently on a 3270,
    Weve had it with the fur in the bathroom, recently started using the shower more often and its begun growing some spots of mold.
    Im planning on ripping it out, sanding everything down and painting it with something like this:
    https://www.amazon.com/Rubberseal-Li...ber+Seal+White
    Id like something smoother, that wont be such an attraction to moisture and mold/mildew, I figure rubberseal will be a good solution for that, but id like to hear an opinion or two before I do.
    Something to make it easier to dry after showering.
    Is that a good idea? Is there something else you would suggest doing with it?
    Interesting, looks like the stuff they cover a roof with. We will await the results I thought about doing something similar.
      I would suggest FRP sheets. Will look much better. Getting any kind of acceptable surface with that stuff will be near impossible.
      1986 Bayliner Contessa 2850
      In over my head for sure!!
      M/V SKUA refit
        I have found that using a bungee to keep the door open after showering helps to prevent mold. I often shower shortly before bedtime, keep the door open and point the portable electric heater at the door opening on the "LOW" setting. Floor is dry in about an hour and everything is dry by morning. Plus if you need to use the head during the night it is nice and warm in there.
        Newport, Oregon
        South Beach Marina
