4788 dimmer switch for rope lights
    Does anyone know where to get the round dimmer switch located just inside the entryway door .
    2001 4788
    Knott again
    I could not figure out a way to copy an eBay link on my iPad to post. Just type in something like this on eBay: Adjustable 12v 8a PIR Sensor LED Strip Light Switch Dimmer Brightness Controller
    this should get you started.
    MV Kia Orana
    Currently Enjoying the PNW
      If you want an exact replacement, IMTRA has them. But they ain't cheap!
      http://www.imtra.com/7c3a8b76-557c-4...ers-detail.htm
      I bought one, but have yet to figure out how to gain access to replace it.
      Pat
      Paragon
      1999 4788
        I can get to the back of mine by removing the battery switch panel.
        MV Kia Orana
          Thanks, I've tried removing the battery switch panel but the rotary switch also has a mounted box, which is mounted in an impossible location to gain access.
          Pat
          Paragon
          1999 4788
            Pat,
            With the panel removed, can you get your right arm to the switch. That’s what I have to do. I also use a mirror and light to get a visual. That’s all I have done so far. I’m going to be putting in another dimmer for the new led rope lights. The new ones are too bright.
            MV Kia Orana
