Removing floor drain screen in guest head - 3988
    The floor drain screen (the chrome screen through which the shower water drains) in the guest head in my 1996 Bayliner 3988 is corroded and I would like to replace it but I need to remove it first. Any ideas about how to remove it?
    If it is like the one in my 4087, it is a press fit into the pipe. I inserted a thin screwdriver in mine between the screen and drain pipe, and popped it out.
