38XX warning buzzer
    38XX warning buzzer
    My warning buzzer has quit for low oil and temp. The buzzer is getting zero volts. I have a gray with red stripe wire adrift with no idea where it might go. I can't find anything on my wiring diagrams for the buzzer. Any ideas? Thanks, TW
    Could be a lot of things, get the voltmeter out and start tracing. I broke my oil pressure switch and gave me no buzzer. Bought a new switch (was from a 70's VW) and has been great since. If you think its a sensor you have another engine to swap parts to find the issue
    1985 3870 175hp Hino's
      I had to go to a 1990 Owners manual to find the alarm circuit. If you have any habits like mine, you probably knocked a sensor wire off the oil pressure sensor switch. If you have Hinos it’s probably a green wire hanging free near the oil slinger. Without the oil pressure alarm switch grounding there will be no power at the buzzer.
      I like to use a cheapo test light from Harbor Freight to look for these things. You can try the gray red wire for key on and off. If there’s not an available connect, it may just be a stray.
      Heres a link to the manual.
      http://bayliner.com/wp-content/uploa...Motoryacht.pdf
        I've done the same thing as Pete on the port engine more than once, I now check it any time I'm in the engine room, and make sure it's connected.
        James
        Hurth 630's Onan 8kw MDKD
        Lowrance Electronics!
        AGLCA #8340
        MTOA# 7469
          Where is this grey/red wire located? Near the buzzer? Not sure if the larger boats have a different engine alarm system than us smaller cruisers do but for us there should be 12volt power to the buzzer whenever the key is in the run posision and the low oil and over temp switches simply close the negative path to the buzzer to set it off.
            Builder, I stand corrected, there should be power to the buzzer then the pressure switch closes the circuit. The power to the buzzer comes from the same circuit as the gauges.
            James, I replaced the wire connector on mine then squeezed each down so that I had to use pliers to get it on. So far, so good.
              Yep the oil pressure switch completes the circuit to ground when no oil pressure exists.
                The gray wire is under the lower helm. Thinking I did something there since I replaced all the instruments due to a lightning strike. Will turn on ignition and ground out oil pressure switch and see what happens. Did not think of that. It was intermittent for awhile which makes me think it might be the switch on the engine. Makes more sense than anything else. Thanks everyone. House got hit by lightning and the boat got zapped via the shore power cord. 15K in damage. Last summer the boat got hit directly on one of the vhf antennas. 22K in damage. Interesting things get zapped. Start relays both times. Fuel tank and water tank senders, charger, tach senders. Alternators and starter bullet proof.
                  Didn’t your insurance cover this as well paying to have the boat repaired?
