4788 Replacement Puck Light Lenses
    Hello folks. I have a '97 4788 and want to replace the interior puck light lenses. I am hoping I do not have to replace the entire fixture. Also, would like to replace bulbs with LED without replacing fixture. Can anyone out there in BOC world point me in the direction to where I can purchase the lenses themselves?
    Thank you.
    Jamie
    Alameda, CA
    1997 4788 w/Cummins
    Boston Whaler 110
    I replaced mine from Salviinco: http://www.salvinco.com/Ringo8308.
    Sailor Sams has them also, but I found at the time the shipping was more than the product: https://www.sailorsams.com/frilight-...-ceiling-light, https://www.sailorsams.com/Replaceme...08_p_4896.html
      I replaced the OEM bulbs w LEDs throughout the boat. Wow! What a difference in lighting. Used direct replacement B-9s. Had a few that wouldn’t
      wired w OEM but did not re-light w LEDs. Maybe a ground issue??? A pair under kitchen cabinet over sink were twist on/off & couldn’t remove less caps to replace bulbs???
      • Woodsea
        Woodsea commented
        I believe some led lights are polarity sensitive. I’ve had some where I had to reverse the positive and negative leads for them to work. Simple to do with a two pronged bulb so it might be worth a try???
      I have replaced most of the floresent lights with 800 lumen LED tube fixtures. Wow, lights up the guest berth better than any of the other LED pucks.
      Passage way and heads are bright! Even add an additional over the cupboard above the sink in galley. About $13 for each lamp & the will plug one to another.
      next project is to do the same on the port & SB balances in salon.
