I completed the latest small project. A couple of Aetna digital tachs plus with two Maretron 4” screens configured to show boost, EGT, fuel tank level and fuel pressure after the Racor. I kept the legacy dials for oil pressure, coolant temperature, and battery voltage even though these values are also available on the NMEA network.
Redesigned 4788 lower helm dash panel
1 PhotoLast edited by ksanders; 12-14-2017, 07:32 PM.Evan
2001 Bayliner 4788 "Fifty / Fifty II"
League City, TX -
Very nice clean look!
4788 DOS PECES - SEWARD ALASKA
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
Wow! NIce, Evan . . . . . now that is one good project . . . you made it look very professional too! Congrats!1998 Avanti 3685 - "Dad's Dream" w 454 Mercs - for sale - Dredge Harbor, NJ
Former - "Home Aweigh" 2003 - 2452 Bayliner Cierra Classic Hardtop Cruiser
WQQM835 MMSI: 338147209
James H. Stradling
Evan,
Did you reuse your existing tach wiring and just hook it up to the new digital tachs? Aetna says to use a twisted pair of wires???
Steve2000 4788 w Cummins 370's, underhulls, swim step hull extension
MV Kia Orana
Currently Enjoying the PNW
Originally posted by egbauman View PostI completed the latest small project. A couple of Aetna digital tachs plus with two Maretron 4” screens configured to show boost, EGT, fuel tank level and fuel pressure after the Racor. I kept the legacy dials for oil pressure, coolant temperature, and battery voltage even though these values are also available on the NMEA network.
Your upgrade looks awesome.... Can you share the sensors and such you used for the boost, EGT, etc? Did you use all maretron parts?
~BJBJ
OMEGA
5788
Very nice!
I also just completed a project that includes a new panel from Mike at A PLUS Graphics.
Installed a iPad mount from Guardian Avionics in the port side of the dash of our 490. I really like how polished the mount looks, and how easy it is to get the iPad in and out (while being held securely).
Still need to install the NMEA to WiFi converter to pull GPS and AIS from the Standard Horizon - once that is finished we will have a completely redundant system (minus radar) for navigation. In the meantime, the iPad GPS works great, but it will be cool to display AIS targets on the iPad too.
4 PhotosGMS
2008 Meridian 490
2010 ArrowCat Express 30 (sold)
- Likes 1
That turned out wonderfully!
I was trying to picture how that would look and it's a LOT better than I even imagined. What a great use for an old iPad laying around. I wish I got to see more of these. I build hundreds each year, but only get to see the finished products a few times a year. Thanks!
I may have to order one of those iPad mounts myself.
ddorsett - The defroster vents are from the reverse cycle heat/air systems that came standard on Meridian 490s. That said, there is TONS of space behind the dash that would allow for after-market options to be installed (may take some creativity to access, but the space is definitely available).GMS
2008 Meridian 490
