Galley Wallpaper Alternative
    I am looking for a material that is available locally to re-do the "aluminum foil" backsplash wallpaper in the galley (as well as the section under the window above the sink... Are there any synthetic type materials that would look good and stand up to the marine environment you would suggest?
    thanks in advance
    What model of boat are you working on?
    Newport, Oregon
    South Beach Marina
        I had a similar thing I wanted to make loom a bit better.., I wrapped the area I tile. I think it came out pretty well..
        BJ
        OMEGA
        5788
        BJ
        OMEGA
        5788
