My port turbo failed on a layover in Monterey. I was on a buoy ball in Monterey and started the engines every week for two hours to charge the batteries and lubricate the engine. The shaft broke and the scuttlebutt is the engine was not in idle long enough for the turbo to slow down, not getting lubrication thus damaging the shaft. I ran the engines at 1000 rpm's then slowed them to idle before shutting down. The engines were at idle for about 30 seconds before shut down.
Questions - At what rpm does the turbo kick in? How long at idle before shut down? Does the turbo spin after the engine is shut down?
