3988 STBD Wing Window Vertical Bar Replacement
    Greetings,
    The vertical bar connected to the window next to the lower helm station of our 2001 3988 fell off and into the water. It may be called a Slider Lock Assembly, but I'm not 100% sure. It's the bar that is used to lock the window and keep water out. I included a picture of what I need. I beleave the part number is 5745R-XU. A cross reference number I found is 1713265. I tried Silver Spring Marine and they said it's no longer available. Does anyone know where to get a replacement? If anyone has an alternative solution besides a direct replacement or Duct Tape, that would work too.
    Thanks and have a great day,
    Bill
    Whidbey Island WA.
    Well, that sucks. If no one comes up with a source you can use the port one as a template to have one machined.
      Flogforfood,
      not sure where you are located but you might try some of the Florida boat wrecking yards. I’ve heard the yards are a source for hard to find items.
      MV Kia Orana
      Currently Enjoying the PNW
