3988. 270hp
    3988. 270hp
    Does anyone know where I can get a shaft coupler for a 2000. 3988 Bayliner with a 270 hp I need the shaft side.The number on it is. 57534.
    What does Philbrooks say?
      Measure the shaft diameter, the flange diameter, number of bolt holes and bolt size, and note the transmission brand and model.
      Call a propeller shop like the Prop shop inc.in Mulkito, WA and have them match it up.
      1-800-634-8318
        Hi Jim
        Marine hardware in Remond Wa. most likely supplied the running gear for your 37 they supplied at lot to Bayliner,call them at 425-883-0651
        good luck Brad
        Brad & Sharon
        Lady Jake
        Anacortes/La Conner, Wa.
          Thank you guys I have talked to Ron at Marine Hardware and they have what I will need.
