I replaced the holding tank on my 1990 4588 in 2016. The yard hauled out the boat and cut out the guest sink vanity and removed the back wall to remove and replace. Vaccuflush was all renewed and connected and all hoses replaced. All went well until last week. I knew the tank was approaching full after 2 weeks aboard at the slip. My wife called me and told me she heard something "pop" on the last flush. When I got back I was surprised to find that the "Tank Watch" light actually did work. The tank was completely full. When I got into the hold I found a mess and cleaned it up. Also found a mess under the shower pan and cleaned it up. Had the tank pumped and rinsed and pumped (twice). A tech came in to inspect and finally identified that the tank had cracked along a lower seam.
I suspect that the yard that did the original install failed to vent the tank properly and relied on the single "odor" filter line as venting. Suspect that they did not understand the power of the vaccuflush. Also suspect that pump outs every 2 weeks with insufficient venting may have taken a toll on the tank flexing it due to limited venting.
I have contacted the yard and am awaiting response to arrange replacement.
I think that the OEM tankage was 48 gallons. Wonder if there is 50(plus) would fit and if there is a stock/OEM available or If it must be custom?
Welcome input on this subject.
Smitty and Ksander were very helpful in the past.
