Hi all,
The subject of prop size/pitch has been an interesting point of discussion among a few of my friends and I who own 5788s. It seems that when the 5788 was built and powered by MAN 610 diesels, there soon became a disagreement between Bayliner and Man concerning several things, one being how the engines didn't perform as Bayliner intended with the prop sizing etc. In a nut shell, the props were pitched too high and bogged down the engines to the point Bayliner released a memo to the owners to not run thier boats over 2000 rpms except under emergency circumstances. I found one such letter in my paperwork. It was interesting.
As i hauled Omega out of the water for servicing yesterday to do th zincs, upgrade the tabs and a few other things, I pulled the props to have them repitched, as well.
I've been having issues with sooting and have spent the past couple months rebuilding this and that trying to get better performance. I replaced the injectors and think I have most things as good as they can get, but still have hindered wot rpm. After hauling out, I finally got a chance to look at props. They are four blade 32 diameter with 35 pitch. From everything I've heard, 35 pitch is way too high. It kind of explains why I run about 6.5 knots at idle... lol...
As I'm getting the props done, I was wondering if any other owners with 5288 or 5788s have redone thier props and/or knew what thier props were pitched at and how they performed. I've calculated the proper sized props should be 32 with about a 33 pitch, but as I'm not super sure what the proper hull factor is, i think it's about 6.8. As I'm unsure though, I thought I'd see what everyone was running.
I look forward to hearing about your props and your boats performance....
BJ
OMEGA
5788
BJ
OMEGA
5788
