Oil residue on top of water (4588 1988)
It could be lube oil of it could be fuel hard to tell unless I am there and can see how it spreads and reacts when released.
With that said it could be as simple as a 'blob' f exhaust residue spilling out all at one time.
It takes very little amount of fuel or oil to make a sheen , les than a teaspoon for sure so fining these are a bit of a hunt.
You say you have no losses or contamination in the lube oil.
Questions for you to get you thinking....
- how much oil residue is in the turbo's turbine housing and the air cleaner
- what do the inspection plates look like on the intercoolers
- when were the injectors last checked
- does it only do this when its cold and the boat has only run at lower speeds
That's a start anyway - hope it helps
"Jim Gandee" post=828817 wrote:
Just notice this while untying my boat at the marina this weekend coming from the starboard engine.
Originally posted by fjfool View PostNo idea if you've resolved this, but does that engine smoke more than the other ? I would be suspect of injectors not firing properly, especially with the lack of maintenance you mentioned. Where are you located ?
