Are the 3870-3888 boats subject to the same fuel tank issues as the 3200 series boats?
fuel tanks-gctid828484
If by issues you mean leaking anytime after the 20-25 year mark, then yes.
Most boats will have fuel tank issues at some point. The newest 38s are 23 years old.
http://baylinerownersclub.org/index....l-tank-removal
http://www.baylinerownersclub.org/in...3870-fuel-tank
http://baylinerownersclub.com/index....870-fuel-tanks
Joel
1987 3818 Hino 175
"Knotty Girl"
Prince Rupert B.C.
That is correct. Mine is a 1991 3888, and I spent 2 years trying to figure out where the leak was. It was kind of intermittent and only enough to be annoying. 2 weeks ago i replaced the tanks and there was a "pea" sized hole in the bottom of one and a few "fizzy" spots on the other. The reason the leak was intermittent was because a lot of crud had settled over the hole and restricted the leak.
The staples were part of the story. The other part is that the shelf the tank are mounted on did not drain well. Standing water, aluminum tank and stainless staples, or in my case screws, set up a galvanic corrosion issue. As was already said, 20 to 25 years seems to be about it. Some have made it thirty years but those are in the minority.
Greg
Newport, Oregon
South Beach Marina
"Albatross" post=828911 wrote:
Isn't the leak generally limited to the starboard tank on the 3288? Primarily due to the slight starboard list?
Greg
Newport, Oregon
South Beach Marina
